01-18-2022 07:44 PM
I am not sure if this is a question for NI, but we are trying to configure a radio. When we open the FRC Radio Configuration Utility, it gives an error: "A JNI error has occurred, please check you installation and try again." "A Java Connection has occurred." Any ideas?
01-20-2022 11:29 AM
Hey andivwh,
The radio utility is, indeed, not built by NI so I have little information about it. Nevertheless, I see someone else has reported this in the ChiefDelphi forums. Hopefully the fix also helps your team: Getting Java error when attempting to run the latest Radio Utility
Cheers,
