01-12-2022 08:53 AM - edited 01-12-2022 09:36 AM
I'm trying to follow along with the Zero-to-Robot tutorial:
and am to the point of creating a project, but my installation doesn't include the FRC RoboRIO template. I've crawled through the package manager, and I have FRC game tools and CompactRIO installed. The RoboRIO does show up in MAX, but I'm not seeing any RoboRIO-specific I/O blocks when I go to add things in the block diagram. I've tried both LabVIEW 2020 and 2022.
I've also tried to manually add the device in a blank project, but nothing is showing up when I try to right click to add a new device in the project. Here's a screenshot showing what I have installed and you can see the RIO in the devices list.
Appreciate nudges in the right direction, or a pointer to a more up-to-date tutorial. Thanks!
- larry, coach for Spectre Robotics 8753
01-12-2022 08:15 PM
Sounds similar to the problem reported here: ChiefDelphi: Install/activate
This happens if the FRC Game Tools are installed before LabVIEW.
I recommend to uninstall and reinstall the FRC Game Tools.
Cheers,
01-13-2022 08:41 AM
Thanks for your reply. It turned out I had a number of missing dependencies - One Windows, and a couple NI. Got everything installed in the right order, running the right version of LabView and I now have a blinky LED on our RoboRIO!
01-16-2022 04:29 AM
I installed LabVIEW on new computers anticipating that when the serial numbers for FRC would be released I could activate LabVIEW and add the FRC drive station and FRC templates. When I try to add the FRC It tells me I have a newer version package manager already installed. I have tried uninstalling using NI unistall, Windows uninstall, CCleaner uninstall, deleting National insturments folders including program files, Aplication data files and windows files. Thank You
01-16-2022 05:14 PM
Please ensure you are using the correct downloads:
For 2022, the LabVIEW version will be 2020 SP1.
Cheers,
