General
FRC Labview 2022 Installer Error - An error occurred while installing a package: ni-skyline-rabbitmq-support (20.5.0.49152-0+f0)
This is a virgin Windows 10 Home System.  It has never had any NI software installed on it, until today.
During installation of FRC Labview 2022 offline installer the follow error occurs.
Additional error information:
An error occurred while installing the MSI at 'niskyline_rabbitmq_configi.msi'.
As such I am unable install this year software.
What is the resolution for this issue?
Thank you
(4,208 Views)
I found the answer, although I don't like it.
I tried everything that was suggested, and the only item that actually worked was to de-select
NI Web Server Development Support for Labview 2020 32-bit
It would be nice if it actually worked instead of having to NOT install a component.
It's only been 6 months since this problem and workaround was identified.
Here's the URL https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000kIbbSAE&l=en-US
Hopefully, this will help someone else that encounters it.
(4,187 Views)
The OpenSSL environment variable in that article worked for me.
That support article is linked here: https://docs.wpilib.org/en/stable/docs/yearly-overview/known-issues.html#labview-installation-of-rab...
(2,739 Views)
