Student Projects
Real-time detection and source location of impulsive audio signals - NI Brazil Academic Competition Winner 2012 - Submission for Student Design 2013
Contact Information
University: Military Institute of Engineering (IME)
Team Members (with year of graduation): Paulo César Prandel (2012), Izabela Lyon Freire (2014)
Faculty Advisers: José Antonio Apolinário Jr., D.Sc.
Email Address: pauloprandel@hotmail.com, izabela.lyon.freire@gmail.com, apolin@ime.eb.br
Submission Language: English
Project Information
Title:
Real-time detection and source location of impulsive audio signals.
Description:
A system for real-time detection and estimation of the Direction of Arrival (DoA) of impulsive audio signals, specifically the signals of gunshots.
Products:
NI cRIO-9022, embedded real-time controller;
NI cRIO-9112, eight-slot, reconfigurable embedded chassis with FPGA core;
Two NI 9234, dynamic signal acquisition module;
NI LabVIEW 2012;
LabVIEW 2012 Real Time Module;
LabVIEW 2012 FPGA Module.
The Challenge
To implement a system for real-time detection and source location of impulsive audio signals, more specifically of gunshot signals.
The Solution
To use National Instruments hardware and software for real-time acquisition and processing of audio signals from an array of seven microphones, providing a graphical interface system to end user.
Introduction
     We present in the following a system for real-time detection and estimation of the Direction of Arrival (DoA) of impulsive audio signals, specifically the signals of gunshots. The NI hardware and a 3-dimensional array of seven microphones were used for the acquisition and real-time processing of the signals.  Once detected the event (impulsive signal), its DoA is estimated using the Generalized Cross Correlation (GCC) with Phase Transform weights (PHAT) to measure the Time Difference of Arrival (TDoA) between pairs of microphones. Parameterized predictions of TDoA's are compared to actually measured TDoA's such that the parameter can be obtained via Least-Squares minimization. Using real-time techniques, there is no loss of information from the environment for the processes of signal detection and DoA estimation occur in parallel. This work is an initial step towards a larger system aiming at locating snipers.
     The spatial array consists of seven microphones. The sounds are collected by the array of microphones and conditioned by a PreSonus FIREPOD, which works like a pre-amplifier and also provides the phantom power to the microphones, preparing signals to be sampled by the acquisition modules of cRIO. Azimuth and elevation angles define the direction of arrival of the  wave generated by the signal source. The hardware and the array of microphones are shown in Figure 1.
Figure 1 - DoA system with the array of seven microphones.
Azimuth and elevation angles define the direction of arrival of the soundwave .
Description of the system designed in LabVIEW
     The signals from all microphones enter the acquisition modules of cRIO, and are digitized simoutaniously at a rate of 51.2 kHz. After sampled, the data is queued by the FPGA, which is physically connected to the acquisition modules. This type of queuing used is first in - first out (FIFO). The data from the FIFO buffer is transmitted by the FPGA bus to the controller via direct memory access (DMA). Once at the controller, the data from one microphone (the upright one) is handled by a routine that runs a detection algorithm in a deterministic loop, which has a known execution time that is maintained at each iteration, as is characteristic of real time systems. This execution time is fast enough to avoid the overflow from the FIFO and consequent loss of data, which could cause failure in detecting an impulsive signal.
     Once  an impulsive signal is detected, the signals from all seven microphones are queued in a new FIFO, which will be transferred to another loop; this non-deterministic loop processes the signal through the DoA estimation algorithm implemented in the controller. This second loop has no constrained time of execution,  performing its tasks as the deterministic loop (priority) releases the processing resources. This does not affect the detection of consecutive signals, as they are stored in the FIFO between the two loops. The overall system is described in Figure 2, the non-deterministic loop in Figure 3, and the DoA estimation VI in Figure 4.
diagrama.jpgFigure 2 - Flowchart showing the operation of the system. The signals are concateneted by the FPGA VI and transmited to the deterministic loop by direct memory access (DMA).
Once detected, the signals are processed by the non-deterministic loop.
Figure 3 - Non-deterministic loop of the controller VI. The signals are transmitted from the deterministic loop
by a real-time FIFO. This loop is executed only if a shot is detected.
Figure 4 - Direction of arrival (DoA) VI. This VI processes the algorithm for DoA estimation.
     Both algorithms, impulsive signal detection and estimation of direction of arrival (DoA), are found in the technical literature and are not described herein for we focus on implementation details. These algorithms are implemented using functions (subVIs) of the system as a whole.
     The results of the DoA estimation algorithm (azimuth and elevation of the incident soundwave) are transmitted through variables to a notebook via an Ethernet connection, the results being shown on the screen in a user-friendly interface (Figure 5), which also allows debugging of possible runtime errors. It is noteworthy that all the processing is carried out in the real-time hardware (cRIO), the notebook being used only as an interface. To make the system more compact, the interface could be performed directly by the cRIO through LED indicators of the direction of arrival or an LCD display embedded in the equipment itself, eliminating the use of the notebook.
interface.jpgFigure 5 - Interface of the system.
Results and conclusion
     The processing time from the detection of an impulsive signal to the output of its DoA is currently (at the time of the submission of this work, i.e., it can be improved with further refinements) within 1.5 seconds, in many applications a derisive waiting time for possible responses actions to be taken by the user. Tests were performed with the system in a laboratory measuring around 4×5 meters using gunshot recordings  played on a sound box model Yamaha MSP3. A loudspeaker was used to ensure a fixed position to a burst of impulsive signals of same characteristic. The speaker was placed (with precision of less than 1 degree) in azimuths 45, 135, 225 and 315 degrees, and 20 shots were "fired" at each position; the results are shown below in the histograms of Figure 6.
Figure 6 - Histograms showing the accuracy of the system.
     The system is highly accurate and fully functional, with a maximum absolute error of 0.2 degree (results for tests in lab conditions). The system also has a conditional structure which checks whether the cross-correlation of signals from a pair of microphones is maximized by an argument outside the range of values that are ​expected, which is given by the distance between microphones in that pair (which can happen in cases of presence of significant noise, for example), and then discards the result of this specific pair and keeps the rest. This contributes to a better overall system accuracy.
     Factors such as high processing capacity and the possibility of simultaneous sampling of all seven channels (microphones signals)  were extremely important for the correct operation of the system. The courses offered by National Instruments and the easy programming environment of LabVIEW to implement the various functions and algorithms, both detection and direction of arrival estimation, allowed the successful development of this project on a tight  time frame (3 months).
     The main difficulty was the synchronization of the various tasks to be performed by the system, where the time factor was crucial due to the impulsive nature of the incoming signals which creates necessity for a high sampling rate. Queuing techniques and synchronization tasks taught during the NI courses were widely used for the solution of those problems.
     This project addressed a problem of public security that has been growing in importance in the worldwide scenario, where the need for detection and estimation of the direction of a firearm shot is very important in combating urban violence; also, this system has application for defense forces.
     In a next step of this project, an analysis of the two signals generated by firing supersonic weapons is to be included; these signals are the muzzleblast, generated by the explosion of the cartridge in the gun, and the shockwave, generated as a supersonic bullet travels through the air. When their directions of arrival are combined, it is possible to estimate the distance of the shooter relative to the array of microphones, along the DoA of the muzzleblast. The estimated location is more accurate when the microphone array is not too far away (otherwise the deceleration of the bullet decreases its accuracy) and also not too close to the shooter, when an overlap of both signals (muzzleblast and shockwave) may occur.
Demonstration video:
          See also the attached poster.
Comments
Casco
Member
Member
on
This is an outstanding paper with such good quality and very suitable application. The presentation has a simple explanation and a well produced video. Congratulations for the authors.
vsenna
Member
Member
on
Excellent!
Mauro_Cezar
Member
Member
on
Great job! Striking! Congratulations for the authors.
velozobrasil
Member
Member
on
Very Good Project!
shikida
Member
Member
on
very cool
Dandolo
Member
Member
on
Excelente.
rocguedes
Member
Member
on
Truly exceptional!
Rublaj
Member
Member
on
Wow. There are so many aplications, but would help a lot at dangerous neighborhoods. Congrats.
geta
Member
Member
on
Muito bom 01!!
Carla_IME
Member
Member
on
Excellent. Congratulations!
Charles.Casimir
Member
Member
on
Nice project! Congrats!
sergioln
Member
Member
on
The project is very interesting and the video is awesome. Congratulations to the entire team (students, supervisor, and video-makers).
pcpellanda
Member
Member
on
Excellent !
pcasilva
Member
Member
on
Parabéns meu amigo! Você merece! Abraço.
Viktor42
Member
Member
on
Parabéns Prandel, excelente!! Vocês vão conseguir. Abraço
Zele
Member
Member
on
Congratulations.
Zele
Member
Member
on
A good solution to a difficult problem.
vitornasc
Member
Member
on
The project and video show impressive results.  High-quality work!
eabsilva
Member
Member
on
Excellent practical work.
Carcará
Member
Member
on
Excelente, companheiro. Os atirdores não estão mais seguros, mesmo com toda aquela camuflagem no lombo, hehehe.
Dani_Sabidos
Member
Member
on
Parabéns pelo extraordinário trabalho desenvolvido.
Dani_Sabidos
Member
Member
on
psrdiniz
Member
Member
on
It is usually difficult to explain to non specialist what can be done with signal processing. This is a beautiful example of what a smart design can achieve.
Calôba
Member
Member
on
Congratulations, excelent work.
santander
Member
Member
on
Parabéns!!!
DenaMedeiros
Member
Member
on
Parabéns!
csmedina
Member
Member
on
Wonderful job and high quality video. Congratulations!
Laine
Member
Member
on
Parabéns! Estamos orgulhosos !! Boa Sorte!
FM-PG
Member
Member
on
Fantástica contribuição !! Parabéns!
mlrc
Member
Member
on
Excellent work! Seems robust and powerful.
Fadul
Member
Member
on
Muito criativo e muito útil. Excelente trabalho. Parabéns aos autores!
Apolin
Member
Member
on
We were among the four finalists and went to Austin (NI Week 2013) where first (Easier Student Science on Sounding Rockets) and second (Autonomous Robotic Technology Enabling Minimally Invasive Surgery) places were announced. It was very nice working with Paulo Prandel.
wanL
Member
Member
on
It's a good jod!
Contributors
