Using the Initialize Device.vi with parameter "Select CUDA Runtime Version" = Default, the CUDA Runtime Version 10.1 is used. Is it possible to use the 11.0 version and how? - After setting this parameter from "Default" to "by path": How should the "CUDA Runtime Version Info" parameter be defined to start the 11.0 Runtime Version?
