GPIB programming in C#
Reply
Highlighted
IronPython 2.7 does not work with Pyvisa 1.6.3
I am new on python , and I just create a small python script to communicate with one instrument using GPIB. and pyvisa 1.6.3
     import visa
     rm = visa.resourceManager()
     my_instrument = rm.open_resource('GPIB::5::INST')
     my_instrument.write('MEAS:CURR?")
     rv = my_instrument.read
     print (rv)
If I run this script with python 3.4, everything works fine
but I want to use visual studio  C# with IronPython 2.7 to control the instruments
and I cant't load the visa.py
I received a lot of error messages
unexpected token 'from'
(because does not recognize "from pyvisa.highlevel import ResourceManager"), I moved the highlevel.py to the same visa.py directory and changed the command to ("from haiglevel import ResourceManager)
looks that the IronPython does not recognize the commanf
"from *
from pyvisa.highlevel) the period on this command
etc.
looks thet the from command does not compatible between python 3.4 and IronPython 2.7
some one knows if I can use pyvisa 1.6.3 under IronPython 2.7?
Message 1 of 1
(1,185 Views)
Reply
