GDS(Goop Development Suite)
Property Method / Property Node
Hi all,
I have started to use GOOP. I would like to fully understund difference between Property Method (Get/Set) and Property Node (Read/Write). Can someone please explain this to me or give me a link to the current EndevoGOOP400 manual?
Thanks a lot.
Pavel
(2,697 Views)
Hi, when you are using OOP (object oriented programming), you describe objects instead of functions or task, when you talk about an common object, let's said a car, the car is a Class an it have properties like:
Color
Number of seats
Model
Brand
number of km
etc.
the properties can be for read an write, in my experience is the same get=read, set= write, you can protect the access of a property only to be written by some method instead allowing the end user to write this property.
Best regards.
(2,675 Views)
