08-04-2016 04:51 AM
Dear NI/GDS Community,
I'm just starting with GOOP Suite, and let me, please, ask you couple questions, on which I haven't found answer yet...
1. While installing GOOP from VIPM, it recompiles all VIs, from vi.lib\addons folder. It takes a tramendeous amount of time... Why it is needed, and what will be the consequences, please, if I'll discard this recompile (I understand, that it is needed for GOOP VIs, but I don't understand, why it is needed for other VIs).
2. Help files are not opened. I can find htm files on harddrive and open them, but via normal open, it is written, that file is not found. I thought, that they are blocked b/c downloaded from internet (what sometimes happens with chtm files), but no...
3. Are there some video tutorials of how and when to use this toolkit? B/c those links from LAVA forum, what were placed here also, are not valid anymore; and on youtube there is no video of how to use it exactly.
Thanks a lot in advance,
sincerely, kosist90.
08-07-2016 11:45 PM - last edited on 03-05-2024 04:29 PM by migration-bot
08-08-2016 11:41 AM
Great, thank you very much!
02-02-2018 04:12 AM - last edited on 03-05-2024 04:30 PM by migration-bot
wrote:
why not try the OpenGDS version
Because the first thing you read on the OpenGDS page is a recommendation to open NI's version:
" I recommend you to use NI’s version to start with: https://www.ni.com/en/support/downloads/tools-network/download.goop-development-suite.html "
It is a bit confusing...
