06-16-2016 02:38 AM
Hi All!
I have started with G# plugin recently, but I yhave encounteresd following error after a clean install of g# and staruml plugin.
When I open a project (that has nothing to do with g# yet) I get 14 dependency warnings like:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\AppBuilder\RW_Project\AB_RW_Project_TargetFile_Info.vi (AB_RW_Project_TargetFile_Info.vi)
- The control expected to be at "<resource>:\Framework\Providers\API\ItemRef.ctl" was loaded from "C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\ItemRef.ctl".
I clearly see that those have nothing to do with my project - rather with G# framework.
I suspect that <resource>: tab is not set correctly in some configuration.
could anybody here help me to get a proper clean install, which will not throw me warnings each time I open a project?
Full warning dump file is attached.
06-16-2016 08:10 AM
I did a fresh install of the G#Framework 1.6.1 earlier today on a LV2015SP1 machine without any problems. Was it during installation of the G# StarUML plugin you got the warnings?
Mattias
06-16-2016 10:46 AM
I have installed g# and staruml in one go.
After installation - every project I open show similat dependency error. I have not checked whether those are identical - but that is my assumption.
06-16-2016 12:38 PM
Isn't this the same of this https://decibel.ni.com/content/thread/40751?tstart=0
I keep on hitting on it.
Cheers
Andrea
06-16-2016 11:39 PM
I tried installing from vipm with version 1.6.1.4 and get similar relink problems.
I uninstalled it and installed from the link Mattias provided (http://addq4.se/download/Files/addq_lib_gsharp-1.6.1.4.vip.zip). Then I get even more relink problems, which is strange, since I did not have them the last time we tested this, and neither did legrimpeur. I'm having trouble with the forum post editor so I cannot post a pic of that without erasing my text.
I uninstalled and then installed from http://addq4.se/download/Files/G%23%20Framework%201.6.1.zip, and i get NO relinks! I suggest using this zip-file instead.
Mattias, I know you love making and testing vipm packages . Could you test and verify?
//Thomas
06-17-2016 01:52 AM
Whoa!
Thanks legrimpeur and thols! Big kudos to you both.
Reading the thread legrimpeur provided got me into some insights of the problem, vhile thols file fixed the issue.
01-18-2017 09:01 AM
I confirm that if I install 1.6.1.4 version using VIPM I get a lot of warnings every time I open a .lvproj (see attachment).
Everything is OK if I install the new version 1.7 announced here.
