G Web Development Software
Slider that is controll and indicator at the same time
Hi, I'm a Uni student, and begginer with NXG.
I want to improve my interface look and I don't know what would be the best solution. I have a webapp that comunicate with my labview dimmable light controll application through websocket. Currently there is a barchart indicator and a slider in the interface. The barchart shows the current level, if I move the slider I can change the brightness and it will be displayed on the barchart. I am not happy with the look of this and would like the control and indicator to be one object. So basically a barchart that I can drag to change the brightness.
Is it possible to do creat something like this? Is there any example maybe?
Thanks in advance for your help
(2,675 Views)
What is it about the slider by itself that you don't like? You could apply custom CSS to modify the styling of the slider as well if needed.
(2,637 Views)
Maybe I wasn't clear, sorry English is not my mother language. So the problem is not the look, I know how to modify it. The problem is that I need an indicator and a control at the same time for this function. Like this:
So when I open the website the indicator shows the currently set value. If I want to change it I can do it using the slider but I want only 1 object, that can indicate the curent value of the brightness when I load the page and the same time can act as a controll, so if needed can be dragged and can modify the value.
The indicator in NXG can only indicate and can't act as a controll. The controll slider can have a default value (which is the value of the slider when the page loaded), but as far as I know it can't be a varriable so its just show the manually set value, doesnt indicate anything.
(2,633 Views)
Accepted by topic author Izohrr
Sounds like you just want to programmatically initialize the control with a property node and then you can use it as a control:
(2,587 Views)
Yes. Thank you so much. This is exactly what I needed.
(2,578 Views)
