Yes you can.
To ensure that clients on other PCs can actually use the font, I deliver it via my website. Here is how I did it:
Note: There might be a better solution cause you still need to fiddle around with the CSS styles of you website quite a lot
- Get a web font kit e.g. https://www.fontsquirrel.com/fonts/open-sans in WOFF format
- examples and CSS files are included
- Place it in you project path and add it to the project
- Add the custom stylesheet that is included with the font to you website
- You then have to apply the font to all the elements you need by using the "HTML class attribute" in G Web
Note: You need to create another CSS file where you create these custom attributes e.g.:
.my-font {
font-family: 'open_sansregular', Arial, sans-serif !important;
.my-font .ni-grid-widget * {
font-size: 16px !important;
This won't work for all the UI element in G Web out of the box, you have to dig into the CSS styles quite a lot to make it work for everything. Maybe there is another way to apply the font for the entire webpage but I couldn't find a way jet.
