08-31-2016 07:38 AM - modificato 08-31-2016 07:39 AM
comme si puo fare update data base componenti? celo bridge
GBU2510,ma no ce dentro
in data 08-31-2016 01:46 PM
o per ex LEM 100 ? TRANSDUCER?
in data 09-01-2016 03:15 AM
Hi johnnewyork,
can you reformulate in English? I'm having a little trouble understanding.
CorraDIT
in data 09-01-2016 03:47 AM
hi,yes of course we can talk in english
first issue-i have varied devices wich i cant find in data base,no phone number,no nothing in website,loose a lot of time and want 5000 for licence!!
for ex LEM 100 or other new model of trasducer
sec issue-from programm and help,i cant understand ,how can i use just one face,no 2 faces
3 issue-from programm and help,i cant understand how can i change the tickness of connections and distance between connections??
i lost time for check info,=impossible,just this forum
in data 09-01-2016 04:02 AM
and more,i cant see any solution for print 3d photo
yes with the phone,very technical
in data 09-01-2016 04:36 AM
I think you should contact the producer of the hardware you are talking about, I am not sure what you are looking for here. Is this NI hardware? What do you need excatly? From what I understand, I think you writing in the wrong forum.
Best,
CorraDIT
in data 09-01-2016 04:47 AM
this forum i believe is for fix all issues with design software,right?
well,
you have any solution? can i have your phone number? or skype?
in data 09-01-2016 04:56 AM
I am very sorry, I know this may sound a bit rude, but I have absolutely no idea what you are talking about. You might want to explain your thoughts to someone who will then put them into words.
Please explain how your questions relate to NI software or hardware, so that we can try to help you better, it's very hard to understand your need from your post.
in data 09-01-2016 05:03 AM
my friend is talk about one new project ,using software ni design for electronical components
i believe who work with this,already know
before to change ,after all work,this software,i try to understand if i can find all answers which i have regarding this software
when i go in ultiboard,i can t find in the menu and practically,how can i change for have only on face of layer,my thickness of connection,distance between connections
