in data 01-19-2011 09:23 AM
Grazie, ho simulato la 6024E ma selezionando dev1/ai0 mi restituisce il seguente errore:
Possible reason(s):
Selected physical channel does not support the measurement type required by the virtual channel you are creating.
Create a channel of a measurement type that is supported by the physical channel, or select a physical channel that supports the measurement type.
Property: AI.MeasTypeYou Have Requested: Pressure:BridgeYou Can Select: Current, Resistance, Strain Gage, Temperature:Built-in Sensor, Temperature:RTD, Temperature:Thermistor, Temperature:Thermocouple, Voltage, More:Voltage:Custom with Excitation
Task Name: _unnamedTask<E>
