FlexLogger
NI 6218
Hi Guys,
I need to log some signals by using NI6218 and read them through Flex-logger.
The problem is I can't see the DAQ name (6218) in the list of Flexlogger.
How to configure NI 6218 to be read by Flexlogger?
(3,977 Views)
Accepted by topic author Ghzoli
Have you confirmed if your version of FlexLogger supports 6218? check the readme file.
Santhosh
Soliton Technologies
(3,972 Views)
Support for the USB-6218 was added in the 2023 Q1 release of FlexLogger. Link
If you are using a version older then that you will need to update in order to get support for the hardware.
Ryan
Group Manager
FlexLogger
NI R&D
(3,970 Views)
Thanks, Rayan for your feedback, Yah it works now.
Also, is Flexlogger compatible with Windows 11? so in this case we can make logging system relay on NI6218 and Windows 11.
Regards
(3,907 Views)
