FlexLogger
Flexlogger only writes to file on logging stop
Flexlogger used to constantly write to the tdms file while logging - this meant that you could read the data and confirm it was logging (while logging) and the data was available even if something crashed.
Somewhere along the way it's been changed to only save to file when you click "stop logging" or close the window. Can it be changed back to constantly write to file so if anything crashes the data is still safe?
Message 1 of 1
(1,513 Views)
