FlexLogger
FlexLogger would not start
If I start FlexLogger after installation, the Start page appears. After nearly one minute the Start page will disappear without any window opening.
The windows Event Viewer reports 2 Errors:
1. A .Net Runtime Error
        Application: FlexLogger.exe
       CoreCLR Version: 6.0.3124.26714
       .NET Version: 6.0.31
       Description: The process was terminated due to an unhandled exception.
       Exception Info: exception code c0000005, exception address 00007FFE4C54346C
2. An application Error
       Faulting application name: FlexLogger.exe, version: 9.13.0.49766, time stamp: 0x65fc0000
       Faulting module name: InProcessClient64.dll, version: 23.4.4.223, time stamp: 0x661e714d
       Exception code: 0xc0000005
       Fault offset: 0x000000000009346c
       Faulting process id: 0x0x68D4
       Faulting application start time: 0x0x1DAE7D8BA4D3A2A
       Faulting application path: C:\Program Files\National Instruments\FlexLogger\FlexLogger.exe
       Faulting module path: C:\Program Files\SentinelOne\Sentinel Agent 23.4.4.223\InProcessClient64.dll
       Report Id: 3070e9f1-beda-437a-9079-6a15ef7f7ecc
       Faulting package full name:
       Faulting package-relative application ID:
What will cause this crash of the FlexLogger?
Best regards
Markus Lorenz
(1,740 Views)
Hi Markus,
Wanted to let you know I’m also seeing this issue and I also have Sentinel One on my PC. I’m thinking it could be related to that application.
Chase Fearing
Test Engineer, Certified LabVIEW Architect
(1,578 Views)
I am also experiencing the same error with SentinelOne. Did you resolve it for yourself?
Best regards
Marcus Mager
(1,486 Views)
(1,463 Views)
Hi Marus,
The issue that you are having regarding the FlexLogger app launcher might be related to the Sentinel One as mentioned by the user @CFEARING01. I would recommend you to follow the following troubleshooting steps and revert back with the results:
1. You can try temporarily disabling your SentinelOne and then try lauching the FlexLogger. If the FlexLogger lauches correctly then you will have to whitelist the following applications for you to keep the SentinelOne enabled and for FL to run perfectly:
  • C:\Program Files\National Instruments\FlexLogger\FlexLogger.exe
  • C:\Program Files\National Instruments\FlexLogger\NationalInstruments.IoDataPef.Engine.exe
  • C:\Program Files\National Instruments\FlexLogger\NationalInstruments.UserAccount.Application.exe (for logging in)
  • C:\Program Files\National Instruments\FlexLogger\TDMS File Viewer.exe (for viewing TDMS files in Lite mode)
  • C:\Program Files\National Instruments\DIAdem <Year>\DIAdem.exe (for viewing TDMS files when licensed) - be sure to add the year of FlexLogger version
2. This particular problem can also occur if the FlexLogger.exe is not placed in the default installation path. Make sure that you have the FlexLogger.exe file in the folowing path: C:\Program Files\National Instruments\FlexLogger
3. If the FlexLogger.exe is already in the default installation path, then try to perform a repair of the FlexLogger via the NIPM or remove and reinstall the software on your PC
Feel free to revert back with your troubleshooting results. I would be glad to help anyone in this problem to solve this issue.
Regards
(857 Views)
