FlexLogger
FlexLogger and PXIe
Dear all,
I am writing to verify the hardware and software compatibility for a system upgrade we are planning.
We are currently using legacy PXIe-8133 and PXIe-8135 controllers. Our goal is to install Windows 10 on these units and subsequently run FlexLogger for data acquisition from the modules installed in our chassis.
To ensure the longevity of this setup, we are considering purchasing perpetual licenses, as we anticipate that future software releases might eventually drop support for this older hardware.
To optimize performance, we plan to perform the following hardware upgrades:
  • Replacing the current hard drives with SSDs.
  • Expanding the RAM to its maximum capacity (8GB for the PXIe-8133 and 16GB for the PXIe-8135).
Could you please confirm if FlexLogger is fully compatible with these specific controllers under Windows 10? Additionally, are there any known limitations or specific driver versions (NI-DAQmx, etc.) we should be aware of for this configuration?
Thank you for your assistance.
(1,110 Views)
The latest FlexLogger 2026 Q1 is supported in Windows 10.
The only problem is that NI does not officially support upgrading PXIe-8133 and PXIe-8135.
You can install Windows 10 manually, but NI will not guarantee functionality, stability, or driver support.
(1,080 Views)
