I'm getting an error when I open FlexLogger 1.7 related to the PefEngineWrapper.vi. I'm aware of the previous issue reported regarding this VI, though FlexLogger does not crash in my case. I get the error message below but FlexLogger can still be opened and used. Though I am unable to run plug-ins developed using the FlexLogger Plug-In SDK in LabVIEW 2023.
I developed the plug-in in LabVIEW 2026 and tested in FlexLogger 2026 with no problems. To run in 2023 software versions, I saved to a LabVIEW 2023 version, replaced the Plug-In SDK dependencies with the 2023 versions, and built the plug-in again. Everything seems to work up to this point until opening FlexLogger 1.7 and the above error shows up. I've attached error report as well.
