FlexLogger
Configure Project to not log some channels
Hi!
we are looking for a way to save disk space by logging only the calculated RMS value of some configured channel. Currently Flexlogger saves both channels to the TDMS file which actually takes more space than just logging the physical channel at high speed, we could then post-process that channel to reduce file size which makes no sense to me, the benefit of calculating the RMS during the test is not interesting anymore.
Is there a way to configure a channel to be available for calculated channels without being logged?
Thanks!
(3,161 Views)
I'd also like to see this feature added if it's not already possible. Just a simple 'log' flag per channel.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(3,071 Views)
I second this, would be a useful feature for us.  We'd want to access the setting via the api.
(2,977 Views)
This feature will be very helpful. Most slow speed datalogging over a long duration will only need the RMS value. For example, I would configure multiple channels at the highest sampling rate and use 50 or 60hz based on the PLC to calculate RMS and log the RMS only. This will save tones of disk space.
(2,672 Views)
Good News!
As of the latest release of FlexLogger 2022 Q2, this is now possible!
More information can be found here
Or in the new manual here
Ryan
Group Manager
FlexLogger
NI R&D
(2,521 Views)
