ni.com is currently experiencing slowness/issues due to ongoing maintenance.
Support teams are actively working on the soonest resolution.
10-23-2020 12:45 PM
We developped a plugin that we sell on the NITN. The development started with R2 version of FL and finished with R3.
Today, a customer called because the plugin was 'hard to setup' because all the settings were 'mixed'.
We discovered that the configuration popup now has all its entries sorted by name !
Previously they were ordered by creation order.
Now the configuration popup is a mess and indeed difficult to understand !
Is this a bug or was it made on purpose ?
10-23-2020 01:50 PM
Its a bug, I'll see if I can get a fix put into the upcoming release
10-23-2020 02:01 PM
Thanks Kevin !
IMO, the best would be to let the plugin developers create this UI...
10-23-2020 02:41 PM
Ya, that is coming at some point (although not actively being worked on yet) 😀
10-29-2020 02:15 PM
Just confirming this is fixed in the upcoming release of FlexLogger.
10-29-2020 02:27 PM
Thank you Kevin !
Any idea on when is the new release coming ?
10-29-2020 02:30 PM
The plan is that it should be available for download in December
