FlexLogger
Calculate Mechanical Power Output Futek TRS605
Hi All, I have a Futek TRS605 Torque sensor with built-in rotary encoder, the encoder is being fed into a NI-9401 to count the pulses (360 pulses/rev) and an analog output from the Futek sensor (-5v to 5V) to show the torque (-50nm to 50nm) into an NI-9205 Card. How can I get flexlogger to calculate the power output using the P = S * T, where S is rotational speed and T is the torque output in Newton meters?
Any help would be greatly appreciated.
https://www.futek.com/store/torque-sensors/shaft-to-shaft-rotary-torque-sensors/non-contact-shaft-to...
Message 1 of 1
(2,273 Views)
