FieldPoint Family
vi startup.exe at cFP-2010 don't starts alone
I'm developing a vi for cFP-2010. When I target cFP the program works, but when I try make startup.exe and make it work alone it doesn't.
I'm using ABCD LEDS for indicate an event, and the leds don't light..
(2,752 Views)
Did you set the start bit on the FP module? Open labview, target the FP module. Go to Tools -> Network: Options -> RT Target Miscellaneous and confirm that 'Launch Application at Bootup' is checked.
Also on that screen confirm that:
Application Path = c:\ni-rt\startup\startup.exe
Downloaded vi Path = c:\ni-rt\startup
Lastly, ftp to the FP module and confirm that c:\ni-rt\startup\startup.exe exists and has a correct timestamp.
Matt
(2,752 Views)
Thanks for your response.
I have found the mistake. If the vi is open when I build startup.exe the exe file don't refresh in the field Point. It's easy, but not obvious.
I have another question. I'm trying to connect to the cFP 2010 by Web. I have activated the web server, but it don't works. I try
http://ipnumber/index.htm
It's the correct address?
Thanks a lot
(2,752 Views)
Greetings,
You may want to walk through a KnowledgeBase that is found on the National Instruments web site which explains using remote panels with a Real-Time target. Follow these instructions and I think you should be ok.
http://digital.ni.com/public.nsf/websearch/A4915E8E1271951086256B22005C2CAB?OpenDocument
Hope this helps.
Patrick R.
(2,752 Views)
