08-25-2008 08:46 AM
hi
i want to upgrade my Field Point (FP-2010) to Lab View 8.6 can i do this
mazhar
08-25-2008 10:48 AM
Hi Mazhar,
I am sorry to report that the the latest version of LabVIEW Real-Time that supports the cFP-20xx series of controllers is LabVIEW 8.5.1. If you would like to use LabVIEW 8.6 and FieldPoint I suggest upgrading to the cFP-22xx series controllers. These are the lowest priced controllers we offer with the highest performance. Please post again if you have any other questions.
08-25-2008 01:01 PM
Eric,
Will the cFP-20xx series be supported on LV 8.6 in the future? This is kind of important for those of us supporting older hardware.
08-25-2008 01:25 PM
Right now, our plans do not include support for cFP-20xx controllers in future versions of LabVIEW. With recent versions of LabVIEW such as 8.2.1 and 8.5.1, we have not supported some features such as shared variable engine. The memory constrictions on the cFP-20xx controllers make it increasingly more difficult for customers to deploy applications to their older FieldPoint systems in newer versions of LabVIEW.
08-25-2008 01:52 PM
08-28-2008 05:50 AM
thanx Eric
09-08-2008 10:49 AM
Just to add my 2 cents worth, I think that NI is making a BIG mistake in not supporting it's products any better than this!! We have a lot of time and effort in these systems, and they're not old enough to even have considered that they would not be supported in Labview updates. I would much rather have support with limitations than a blanket "not supported". This is the first checkmark that I have in the con column against NI, and I have been an advocate for over thirteen years.
Gary
10-07-2008 10:15 AM
10-11-2010 01:28 PM
I have LabVIEW 9 installed on my computer. When I try to target my LabVIEW to a Compact FieldPoint cfp-2020 target, I get a message saying that "the version of LabVIEW on your host is not compatible with the one in the target": how can I fix this probleme?
I apologize to trouble you and thankyou very much.
please, if it can possible, send me the response to my email hassan.or@hotmail.com.
10-11-2010 02:06 PM
As this post suggests, you have to use labview 8.5.1 or below to interface with those devices. You can obtain an install disc for earlier versions of Labview and as long as you are not running both versions of labview on your computer at the same time, you will not be violating your license agreement (as far as I know).
