FieldPoint Family
starting a VI on FP2010 without host computer
I'd like to do exactly what Aaron G is proposing but in LV 8.5. I can't easily find howt o set a VI that it appears in the FP start-up folder.
Does anybody have a hint for me?
Olli
Message Edited by Olli on 08-28-2008 04:44 PM
Message 11 of 13
(1,275 Views)
Olli, In project explorer, create build specification under the target and create the .exe. Right click on the new build specification and select ' Set as startup'. You will notice a small change in the appearance of the icon in the project explorer. Now you can right click the build spec and deploy it as a startup app.
Message 12 of 13
(1,265 Views)
Hello Centerbolt,
many thanks for the hint. It seems to work, because I recieve the following message after software reboot and re-connect to the target: This VI is part of a Real-Time Startup Application. All VIs on the target will be closed if you choose to refresh and continue with deployment.
It would be better, if the start-up VI's keep on running. But it is not a problem, because I can then start them manually.
At the moment I can't test a hardware reboot, because the system is installed on an other location.
Have a nice day!
Olli
Message 13 of 13
(1,257 Views)
