08-28-2008 09:43 AM - edited 08-28-2008 09:44 AM
I'd like to do exactly what Aaron G is proposing but in LV 8.5. I can't easily find howt o set a VI that it appears in the FP start-up folder.
Does anybody have a hint for me?
Olli
08-28-2008 10:36 AM
08-28-2008 12:07 PM
Hello Centerbolt,
many thanks for the hint. It seems to work, because I recieve the following message after software reboot and re-connect to the target: This VI is part of a Real-Time Startup Application. All VIs on the target will be closed if you choose to refresh and continue with deployment.
It would be better, if the start-up VI's keep on running. But it is not a problem, because I can then start them manually.
At the moment I can't test a hardware reboot, because the system is installed on an other location.
Have a nice day!
Olli
