hello bingocom
To run the vi at startup in LV7 you have to:
close your vi, Switch Execution target to your fp-2010 (on the first screen, or undet the Operate menu).Choose Build Application or Shared library In the Tools menu ,Insert the Source Files (your vi), and mark the option "Set target to launch Application at Boot-up" at the Application Settings Tab. Press the Build button and follow the instructions.
See also p. 3-8 at the Real-Time Module User Manual.
success !
Shimon
___________________
Try to take over the world!
