FieldPoint Family
scaling values for Fieldpoint
I am trying to scale 4-20 mA input signals in Fieldpoint. I am accessing the Fieldpoint I/O via a C# application using the .Net data sockets provided with Measurement Studio. I was told I could use Measurement & Automation Explorer. I have MAX 3.1 and Fieldpoint 4.1 installed. I also have the evaluation version of Measurement Studio installed. I am having 2 problems.
1. When creating scales in MAX, I cannot edit any of the fields. A developer I am working with can on their computer. The only difference is they have a licensed version of Measurement Studio. As this task does not use Measurement Studio, I can't see how that makes a difference.
2. I can't see how the scales are linked to the signals.
Any help would be appreciated, including telling me I am going about this all wrong. The C# application I am using doesn't currently do scaling internally so it would be a big benefit to have the scaling done on the I/O side.
MartyW
(3,142 Views)
Marty,
The Scales in MAX are related to the NI-DAQ and DAQMx drivers. They do not work with FieldPoint. The NI-FieldPoint driver does not currently support scaling from the Engineering Units to user defined units. You will have to do the scaling yourself in your application.
Aaron
(3,137 Views)
Thanks. Not the answer I wanted but at least it is definitive.
(3,134 Views)
