06-26-2007 07:04 AM
06-29-2007 02:15 AM
Hi Armen,
so when you have full access to fp folders i would recommend to reinstall your fieldpoint driver under www.ni.com/support
Have you try if the same happens when manually download item names by right click on fp modul ...
Best Regards
AE Munich (Germany)
06-29-2007 07:24 AM
07-03-2007 04:39 PM
07-04-2007 02:19 AM
07-04-2007 10:46 AM
07-05-2007 02:56 AM
Please look in my *.doc i attached here - there you see 2 screenshots of my MeasurementAutomationExplorer (MAX version 4.2.1)
When you click to your Fieldpoint Target - by me cfp 2020 or FP 2000 you can click in the middle to register card fieldpoint access control and proof if all is set to read/write with * for all ip addresses.
When is the same as by me and you have also set download item names on save under tools - fieldpoint settings in menu of MAX then you must install completely new your fieldpoint device because anything must be false (before you must uninstall all - best is to click on device in MAX and click to format disk...)
Best Regards
07-06-2007 03:38 AM
Hi Johann,
Thanks, I have found the mistake. There was another nonconnected bank, which has a same name. So MAX correctly reported about save problem.
08-04-2015 05:17 PM
Amine, would you please explain how did you fix it ?
thnaks
08-09-2015 08:49 AM
