05-10-2010 03:09 AM
Hi all,
I'm working on labview with fieldpoint modules. Why can't I connect the FieldPoint IO Point Constant directly to the FP Read (Polymorphic)? It says "I connected 2 terminals of different types". But somehow I found some manuals on NI which said these 2 items could actually be connected. I use Labview 7.1.
Nicky
Solved! Go to Solution.
05-10-2010 09:52 AM
05-10-2010 01:41 PM
Hi Ravens,
The attached image is the problem i have. I suppose this couldn't be happen since I use the ver.7.1. Hope you can gimme an idea.
05-10-2010 02:48 PM - edited 05-10-2010 02:56 PM
That Fieldpoint Icon looks different from the one I'm used to seeing. Unfortunately, my PC that has 7.1 on it isn't running anymore, so I can't check that far back.
The error tells you something about what it is looking for (cluster of 2 elements). Turn on context help for the Fieldpoint function. Delete the broken wire and right click on the connector input and select Create Constant. With either of those, you should be able to find out some information as to what is required in that "cluster of 2 elements".
Here is what mine looks like. I am curious to know where you got your Fieldpoint function from. Is it from an older version of LabVIEW than 7.1?
What version of Windows are you using? The font that is showing up on your block diagram looks oddly blocky.
05-10-2010 03:58 PM
05-12-2010 06:00 AM
Hello Nicky,
what do you see if you just rightclick the input and choose create => constant. I don't have it installed either.
05-12-2010 06:12 AM
05-12-2010 08:09 AM
05-19-2010 09:10 AM
