10-09-2008 08:30 AM
10-12-2008
10:05 PM
- last edited on
05-08-2026
08:53 PM
by
Content Cleaner
Hello Taycar,
Thank you for contacting National Instruments! I have looked into your question and I believe that I have found some documentation that may assist you. Please look through this Knowledgebase article [link removed; article no longer available] as it should help get you started in the right direction. There are also some links to a few tutorials at the end of the article that may be of interest. If you have any questions after reading through this material please just post them here. I hope this helps! Have a great day!
10-13-2008 07:14 AM
These links still don't address changing the power-up state settings programattically. I want to be able to set the power-up states from within my Labview program. All of these links refer to making changes through MAX.
10-13-2008 04:35 PM
Sorry to report that you cannot set your startup states programatically. If you tell us more about what you would like to accomplish we might be able to find a work around.
10-16-2008 08:02 AM
Taycar,
Search for a document called "Using Advanced DataSocket Commands with FieldPoint Ethernet Network Modules". There is a Snapshot command that will allow you to set the current values (along with ranges, attributes) as the power-up state for a bank. I'm not sure why someone from NI would tell you that there isn't a way to do it? One caveat, it seems that you must wire the url directly into the DS write for the commands to work. It doesn't work if you Open a reference, Write and close (I am about to post a question as to why that is)
Brian
10-16-2008
08:17 PM
- last edited on
05-08-2026
08:54 PM
by
Content Cleaner
Here's the link: Using Advanced DataSocket Commands with FieldPoint Ethernet Network Modules [link removed; article no longer available]
Snapshot Command
The Snapshot Command part of a URL provides you with a single-step method for saving all of the current settings, such as ranges, attributes, and current output data values, as the power-up state for the bank. When 1 is written to the Snapshot Command, all modules in the bank store their current channel outputs as the power-up outputs. The Snapshot Command part of a URL has the following format:
\\machine\FP\Control\Snapshot
