FieldPoint Family
modifying fieldpoint configuration in labview
I try to solve a problem and up to now do not find any solution, could somebody help??
I have an application working with fieldpoint module (one ethernet head FP-1601 with io modules FP-AI-100, FP-AO-210, FP-DI-300 and FP-RLY-420) this application is supposed to work on different machine (AI and AO range are differents) so I'm trying to find how to dinamically inside my application change the range of AI and AO as we normally set this in MAX.
If this is not possible, could it be possible from inside the application to manage a set of different IAK files, those will be then pre-created with MAX for the differents machine?
Thanks for any help!
(3,018 Views)
Changing the input configuration programmatically, thought if current or voltage input and ranges etc., isn't possible with the normal FieldPoint VI's in LabVIEW. These settings can only be altered and saved with the IAK- file, which needs to be available, when you try to connect to the FieldPoint System via Server (this is done at latest when you call the first FieldPoint VI). Some other attributes can be changed programmatically by creating a specific item.(How Can I Programmatically Change Configurations of a FieldPoint Module?   http://digital.ni.com/public.nsf/websearch/960F6F90436A1A1A86256FBA0062E463?OpenDocument) Which items these are, is specific to the FP- module.
If your are familiar with FieldPoint programming using Datasocket, then you are able to change channel ranges programmatically (you don't need an IAK- File for that)
Introduction to Using DataSocket Commands to Communicate with FieldPoint Ethernet Network Modules:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/a6617392b393c4b886256acb005...
Using Advanced DataSocket Commands with FieldPoint Ethernet Network Modules: http://zone.ni.com/devzone/conceptd.nsf/webmain/BE31272F09BBBE1C86256ADC00743576?opendocument#2
Programmatically Changing the IAK Configuration File Used By Measurement and Automation Explorer?  http://digital.ni.com/public.nsf/websearch/AD7E2B97C60086B886256DDE006FBED2?OpenDocument
Good luck,
Stefan
Impossible is nothing - nothing is impossible
(3,010 Views)
