06-14-2012 05:24 AM
Hi vijay,
to perform a loopback test on the RS232 port of you PC, simply connect pin 2 and 3 with a wire (as shown in the picture) and then use one of the software explained in the document.
Bye,
Licia
06-14-2012 07:50 AM
Respected Licia,
Thank you very much, I have connected pins 2 and 3 to perform a loopback test on the RS232 port to PC.
I tryed through performing loopback test through MAX, i cannot get serial and parallel under device and interface to follow.
I just click find device in MAX under device and interfaces, i received this command as "an unknown internal condition has occured, possible cause unrecoverable operating system error".
Kindly help me to proceed.
Thanking You
Yours friendly
vijay
06-14-2012 10:07 AM
Hi Vijay,
so you cannot see Serial and Parallel item under Devices and Interfaces in MAX?
Does the error occur when you right-click FP@COM1 item added under Devices and Interfaces and select "Find Devices"?
Try to reboot the FP-1000.
Is the status LED of FP-1000 off or is it blinking?
Bye,
Licia
06-14-2012 02:01 PM
Respected Licia,
Thank you very much, I had uninstall Fieldpoint 6.0.10 and again install Fieldpoint 6.0.10.
I click FP @ COM5 under MAX under device and interfaces and click find device, The error result was not received.
but this time also i cannot get serial and parallel under device and interface.
The status of LED of FP-1000 is on continously by green colour. but now LED colour of NETWORK is orange before it shows green colour.
Kindly help me to proceed further.
I am onceagain thanking You very much for your timing help.
Yours friendly
vijay
06-15-2012 03:09 AM
Hi Vijay,
I'm sorry but I don't know if I have clearly understood your situation.
1) Try to delete FP@COM5 and try to redetect the system by right-clicking on Devices and Interfaces >> Create New >> FieldPoint Serial. Select the COM port to which you have connected the FP-1000, the correct baud rate (as set with the FP-1000 switches) and check option to "Auto-detect modules". Does the timeout error still occurs?
2) The item "Serial and Parallel" to perform a loopback test on the RS-232 port of your PC should be directly under Devices and Interfaces, not under FP@COM5, as shown in attached screenshot: isn't it there?
3) Status LED always on and not blinking means that initialization failed, as explained here.
This is the meaning of NETWORK LED:
The network led can act in four ways. The first two are normal, the second two indicate that there is something wrong.
Please confirm the exact status of the Network LED and perform the steps in my point 1).
Did you try to connect the FP-1000 to another computer?
If you confirm it is an hardware problem caused by a faulty FP-1000, you need to call your local National Instruments Technical Support to send the FP-1000 to repair.
Bye,
Licia
06-15-2012 05:48 AM
Respected Licia,
Ans:
I delete FP COM 5 and follow your instruction under Device and Interfaces >> Create New >> FieldPoint Serial, after that i confirmed that COM 5 port is working. The baudr rate is already indicates there 115200, Time out 250 ms.
I am unable to find Auto-detect modules to checck the time out error.
Ans: "Serial and Parallel" is not under Devices and Interfaces
3) Status of network LED
In normal conditions
network LED is off.
Power LED is solid green
Access LED is off
Status LED is Off
When i connect pins 2 and 3 to carried out loopback test,
network LED is solid yellow colour
Access LED is off
Status LED is Off
Ans: I now try with my old computer windows 95 version and LabVIEW 5.1 is already installed, which is originally connect to instrument.
If i click Device and interfaces under MAX, "Serial and Parallel" is not showing under Devices and Interfaces,
But i noticed GPIB Interface not found. and the staus of LED in normal conditions is shown below:
network LED is off.
Access LED is off
Status LED is Off,
If i click Field explorer version 1.6, IA server with PC, i noticed Field point iak operation was successful. If i click field point green run button and red stop is indicated.
I am waiting from your suggestion to proceed further.
Thnaking You
Yours friendly
Vijay
06-15-2012 01:34 PM
Respected Licia,
Following my previous mail today,
I again try with my old computer, windows 95 version and LabVIEW 5.1 which is originally connect to instrument.
I double click Field point Explorer sc03rudi.iak , and make it run, then i noticed LED light
network LED is blinking with yellow colour
Access LED is solid yellow colour
Status LED is Off,
service name - Field point
Status - IAK Operation was successful
I also receive one mesage as Fieldpoint explorer has caused a stack fault in module Fieldpoint explorer explorer.EXE in
0137:00406914.
I am waiting your help to proceed further.
Thanking You
Yours friendly
Vijay
06-18-2012 10:07 AM
Respected Licia,
I follow Field point manual regarding to confgure Field point system,
1. Field point system is powered on
Ans: Yes, Field point system is powered on
2. Input / output module - Ready LEDS is LIT
ANS: Yes, input / output module - Ready LEDS is LIT
I try with windows 95 version and LabVIEW 5.1
I double click Field point Explorer sc03rudi.iak , and click Find, Device,
Status : No modules were found
then i noticed LED light status
Access LED is off
Status LED is Off,
From the common resource configuration window, shows
The default name of the COM Port is FP Res,
Default Port is COM1
Default Baud rate is 115200
Timeout (msec) 200
From the Field point manual, I noticed for the reason if No device were found, check
1. Field point Hardware is powered on
2. Switch settings for baud rate match settings of network modules
3. No two network modules on same communication port have same address switch settings
4. Check selected COM port to which you have entered
The point No 1 and 4 is working for me but i do not know to prceed step 2 and 3.
I would kindly request you to proceed me..
Thanking You
Yours friendly
Vijay
06-18-2012 01:11 PM
Respected Licia,
Follwing my mails,
In windows 95 version and LabVIEW 5.1
GPIB software 1.30
IN MAX under Device and manager I noticed GPIB interface not found
I would kindly request you to help regarding communication of GPIB instruments via MAX
Thanking You
Yours friendly
Vijay
06-22-2012 04:18 AM
Respected Licia,
I installed Labview 2011, I confirmed FP 1000 configure in MAX, I also noticed serial and parrllel under device and interface in MAX.
COM Port 3 is found serial and parrallel. Device status : This device is working properly.
I connect RS232 port to USB device to connect laptop. I am unable to see USB under device and interface in MAX.
We are also using Labview 5.1 for our instrument operating in windows 95 version.
National Instrument GPIB software 1.30 were used.
So i also installed NI-488.2 drivers software and noticed under device and interface in MAX
Is i need GPIBO (PCI-GPIB) to communicate with my instrument in labview 2011?
I would kindly request you to please help me.
Thanking You
Yours faithfully
M. Vijay
