07-31-2008 05:02 AM
08-01-2008
08:25 AM
- last edited on
03-18-2025
04:44 PM
by
Content Cleaner
Hi.
I would like to ask you further explanation: why is network connection lost? Do you obtain some error in your LabVIEW application when the connection is established again? Is your program running embedded on the FP or you deploy and run it again from LabVIEW after the connection is re-established? Can you always control the digital modules from MAX?
I advise you to read this KB: AE KB 2FT7TI9O: What Happens if FP Read is Called and the FieldPoint Network Module is Offline?
hoping it's useful for your problem.
Licia
08-01-2008 09:02 AM
08-01-2008
09:06 AM
- last edited on
03-18-2025
04:44 PM
by
Content Cleaner
You are right! Thank you! Sorry for the mistake!
This is the correct link.
Hi!
Licia
08-04-2008 02:34 AM
08-04-2008 07:28 AM
To guard your system against failures in the network connection, cables, or host computer, a possible suggestion is to enable (in MAX) the network watchdog feature of the FP-1601 . If the network watchdog is enabled and the FP-1601 loses communication with all hosts or clients over the network, the FP-1601 sets its output channels to your pre-defined values (the watchdog state).
Licia
08-04-2008 07:49 AM
ok
the watchdog sets the output but the program is tilted.....
I must restart labview when the comunication with the net return.....
This is impossible, there is an error, other pc have a right behaviour and when the net is disconnected have like output the old values
08-04-2008 09:44 AM
I'm sorry if I insist with questions, but I would like to fully understand your problem...
After the connection is re-established, you have to restart LV but you can't? What kind of error is produced? Could you post a screenshot of what is happening?
So your problem occurs only on one computer, while on others all is ok? Maybe the problem is then connected with the connection settings of the computer...
Thank you. Bye.
Licia
