09-28-2009 03:42 PM
09-29-2009 03:18 PM
Hi N.Bass,
What do you mean initialize? Are you setting the channels through MAX and data neighborhood? When you add the cFP-1804 to MAX and then move the FieldPoint to a different machine, you shouldn't move the modules. You'll either need to send commands to reconfigure the module or connect it back to MAX to reconfigure the modules.
Since you're on a Mac, your VI uses Optomux commands to control the FieldPoint. I would check your VI to see if it's calling the correct address and using the correct command to read the analog input.
You can also verify that the driver correctly reads the Analog Input module in MAX by selecting your module in Data Neighborhood and selecting the Start button at the top of the window.
09-29-2009 03:20 PM
Here is some references for Optomux Programming:
http://digital.ni.com/manuals.nsf/websearch/A62558E5BDED8486862573460055DF12
How Do I Effectively Use the FieldPoint Optomux Commands?
http://digital.ni.com/public.nsf/allkb/3EC99318D768D87E86256E0D007FBFEE
