02-26-2010 09:47 AM
Hi Yves,
please report me your results and tell me if i can help you.
03-02-2010 01:42 AM
Hi
I don't get it.
The 33162 errors occurs quite randomly. But hardly ever they last for about 5 to 6 seconds.
Now I'm looking to monitor network traffic and cpu load.
Maybe...
03-02-2010 07:23 AM
Hi Yves,
can you post some code for me so i can look into it?
What are the results, how looks your network traffic?
03-02-2010 09:48 AM
Hi Alex
Thank you very much for your support.
I might have found the error: In a small subvi I found a while loop running without any timer... (And because I load some vi's dynamically and reentrant there were more than one.)
In fact I would have expected a rise of cpu load du to this but there was none.(Maybe due to the quite short time the while loop was running.)
Up to now I had no communication error for 8 hours.
Well I found it quite odd that the error message lead me to a communication failure...
Yves
03-09-2010 02:29 AM
Hmmm, thought I had the error. But I wasn't lucky.
I have set a "Get/Time in seconds" in the acquisition loop. And I compare the elapsed time between every cycle.
And now I have seen that this loops isn't running fast enough from time to time. Sometimes it take more than 5 second!
Although I have set this loop on high priority.
How can I check where this problem comes from?
Yves
03-10-2010 01:16 AM
Hi Yves,
how looks the CPU in the task manager.
Can you please post some code so i can look into it?
How fast should the loop run?
Are you using Timed Loops on your windows system to get the values back from the cFP-1808?
09-16-2010 03:14 AM
Hi Alex
I just wanted to thank you and all the others for having tried to solve my problem.
It sounds really incredible.
By great luck we found out what the problem was: Our lab consists of 10 "Fieldpoint-station". In one of those station was a water leak which drops on the 24VDC power supply for the FP-Controller. From time to time, of course.... Murphy
The water drops came from a pneumatic valve block right above the power supply.
Due to the water drops the power supply stopped and started again. And of course the FP-Controller had to start again to. Unfortunately this problem occured on various time and couldn't be tracked very easely.
Yves
09-17-2010 01:26 AM
Hi Yves,
thanks for this information i think that was realy Murpy 🙂
