09-12-2007 06:31 PM
09-17-2007 12:04 PM
09-19-2007 08:51 AM
03-13-2008 02:52 PM
03-14-2008 12:29 PM
There are several ways to communicate with the FieldPoint. The most common method would be to use shared variables, but direct TCP/IP communication is also available to you.
Real-Time VI To Host VI Communication Methods
Let us know how things progress!
03-14-2008 01:06 PM
03-14-2008 01:14 PM
03-14-2008 01:49 PM
03-14-2008 02:29 PM
Do I need to write the code on the FP in LabView as a Vi?
03-17-2008 09:16 PM
You don't need to:
Can I Use Microsoft Visual C++ 6.0 and/or Visual C++ .NET with My FieldPoint Modules?
Can I Use Visual Basic with FieldPoint?
However:
FieldPoint Measurement Studio 7.0 Visual C++ API Has Been Obsoleted
In your case, I believe you will be able to write this code in C. When you install the FieldPoint software, a LabWindows/CVI Instrument driver for FieldPoint is installed if LabWindows/CVI has already been installed on your computer. This includes functions panels to call C functions that directly access the I/O items you configure in the FieldPoint Explorer program. In addition, examples are placed in your LabWindows/CVI samples directory and will be your best way to familiarize yourself with these functions.
Hope that helps,
