01-25-2007 02:02 PM
01-28-2007 08:17 PM
Greetings!
If you are using LabVIEW 8.2, then you are right in considering the 5.0.1. It is not corrupt, you should be able to download from the following link and install it in the deployment system. That very well could be your problem. It is important that you have the LabVIEW run time engine, Fieldpoint drivers. Also attached is a snapshot of the max help that has good information about assigning ip address to the target.
The red x means usually there is no active connection from the 1808 to the host.
1) I would recommend also narrowing down the test to just using a cross over,
2) flipping the dip switch on the 1808 to ip reset and safe mode.
3) Also observe the indication on the LEDS.
The cFP getting started guide is another great resource you should refer to.
Thanks and hope this helps
Regards
Avi Harjani
