FieldPoint Family
cFP-DIO-550 Won't Power Up
I just installed a new cFP-DIO-550 module in my compact Fieldpoint system.  The unit was tested yesterday and performed perfectly.  Today, upon booting up the system, I notice that the DIO-550 module won't power up.  When I connect power, all the status LEDs on the module flash dimly, then go out.  All the other modules are working fine.  I know there's a firmware issue in the knowledgebase similar to this one, but it only applies to Rev. D and earlier, while mine is Rev. E.  How can I resolve this issue?
Martin
(3,801 Views)
Martin,
Suggest you move the cFP-DIO-550 to a different slot on the backplane and double check any power supply connections/voltages to the module.  If it still doesn't work, it's most likely a case of infant mortality and you'll need to contact NI.
(3,796 Views)
I've moved the module to several different backplane slots and paired it with a known good connector block.  Still having the same problem.  I'll contact NI and see what they have to say.
(3,791 Views)
Hi MrFisher,
Could you please let me know if this issue has been resolved after speaking with NI? Thank you.
Steven
(3,777 Views)
Yes, after contacting NI, they're taking the unit back for repairs.  It seems to be a case of infant death.
(3,775 Views)
