06-16-2012 08:16 PM
I have a cFP-CTR-500 with unused counter inputs and need to count pulses from an encoder for more than 16 bits. (I'm currently using counter inputs 0 and 1 to measure frequency of the encoder.) Is there a way to cascade the counters to create a 32 bit counter? I found Cascade Counter Example.vi but am having difficulty converting the concept from FieldPoint. (I'm not familiar with FP) I also need the cascaded counters to be resettable. I'm under a very tight schedule so example code to import into my project would be much appreciated. I'm using LV 2011 but can upgrade to 2012.
DJ
06-18-2012 07:01 AM
Simple search turned up this. Should work for the cFP-CTR-500 as well.
