FieldPoint Family
cFP-2200 Solid Status Light
I have a cFP-2200 system that has a solid status light. NI manual says this is a Unrecoverable error "Please contact NI". All I did was shutdown the HMI, then power off the CFP. When I turned it back on, our monitoring system (What our cFP-2200 is controlling) said no communication. Dug through the max program and all settings are the same but it shows that it cannot connect to the IP address for the cFP. Power cycled and rebooted systems numerous times in my current troubleshooting
Is the solid status light a definitive "Your system is dead" or is there a way I may be able to bring this system back to life? Im pretty sure I have backups of all the config files and the appropriate software, Im just worried that if the PC cannot even connect to the cFP I may not be able to re upload anything.
Thanks for any help
(332 Views)
Added detail: put the cFP into safe mode and that allowed our PC to connect to it. Got a good ping at the requested IP address. Does this point to any problem specifically?
(313 Views)
