07-14-2006 12:55 PM
07-17-2006 03:34 PM - edited 07-17-2006 03:34 PM
Message Edited by Ryan V[DE] on 07-17-2006 03:36 PM
07-18-2006 09:04 AM
Thanks Ryan
That helps clear up much of my confusion. When you say "Once you get this working, all you need to do is change the VISA resource to correspond with the serial port on your FieldPoint." that is literally all that I need to do is just change the resource? From what I've read I had the impression that I needed to target the Field Point controller with Real Time in order to do any serial communication between it and whatever you have communicating with it but this is incorrect?
I am also not sure what type of VISA resource name to use. The host computer is communicating to the FP module through an IP address. From the list below I've been trying to use the Serial INSTR interface protocol but either I am entering it incorrectly or this is not the one to use. Using the VISA find resource VI all I find are the host computers serial ports.
Well I'm going to keep trying but if you have any more input to my new questions I'd greatly appreciate it.
Interface | Syntax |
VXI INSTR | VXI[board]::VXI logical address[::INSTR] |
VXI MEMACC | VXI[board]::MEMACC |
VXI BACKPLANE | VXI[board][::VXI logical address]::BACKPLANE |
VXI SERVANT | VXI[board]::SERVANT |
GPIB-VXI INSTR | GPIB-VXI[board]::VXI logical address[::INSTR] |
GPIB-VXI MEMACC | GPIB-VXI[board]::MEMACC |
GPIB-VXI BACKPLANE | GPIB-VXI[board][::VXI logical address]::BACKPLANE |
GPIB INSTR | GPIB[board]::primary address[::GPIB secondary address][::INSTR] |
GPIB INTFC | GPIB[board]::INTFC |
GPIB SERVANT | GPIB[board]::SERVANT |
PXI INSTR | PXI[bus]::device[::function][::INSTR] |
PXI INSTR | PXI[interface]::[bus-]device[.function][::INSTR] |
PXI MEMACC | PXI[interface]::MEMACC |
Serial INSTR | ASRL[board][::INSTR] |
TCPIP INSTR | TCPIP[board]::host address[::LAN device name][::INSTR] |
TCPIP SOCKET | TCPIP[board]::host address::port::SOCKET |
USB INSTR | USB[board]::manufacturer ID::model code::serial number[::USB interface number][::INSTR] |
USB RAW | USB[board]::manufacturer ID::model code::serial number[::USB interface number]::RAW |
07-18-2006 07:38 PM
07-18-2006 11:42 PM
07-19-2006 08:36 PM
