Dave,
One minor correction to your code. In the Expiration Actions cluster, checkmark the box that says reset. The Trigger line and trigger protocol are not supported in FieldPoint targets, so the trigger line should remain as none.
A possible alternate implementation, though I have never tried it, is to use the occurance option (which is supported in FP targets). You could have a code segment that writes to the outputs and only executes if the watchdog occurance triggers. The drawback to this approach is that if a part of your code has locked the controller (for example a while loop with no delay overloading the processor), the system may not have the resources to allow the code segment to run.
Aaron
Edit: Corrected misspelling of one word.
Message Edited by Aaron G on 03-08-2005 11:16 AM
