Hey everybody,
I have 6 cFP-1808s running through an ethernet hub with the control PC also plugged into the "downstream" side of the ethernet hub, to put them all on the same subnet. However, I have 4 of them running, one is out of commission until the electricians power it, and one is recognized by the system but the system cannot find any of the I/O hardware.
The six setups are identical, and four run properly. I know the hub and cable are ok, because I can unplug them from the unresponsive unit and control others with them.
The unresponsive 1808 shows up in MAX, but it returns the error every time I try to "Find Devices."
The current IP setup is:
IP Address: 198.162.1.103
Subnet: 255.255.255.0
Gateway: 198.162.1.1
DNS Server: 90.0.0.3
Computer's IP: 198.162.1.100
The ethernet hub is not actually connected to the internet. All the other 1808s are various 198.162.1.xxx (not 103!) with the same other settings, and identical hardware setups (an AI-111, two DI-304s, a DO-401 and 403, a TC unit).
I looked through the KBs and forum posts, but those were all about how to set the IP and such. Any suggestions?
