It is not a good idea for you to use the other channels to measure analog voltage.
Each channel on the module contains an excitation line and two input lines that measure the resistance across the strain gauge. The internal circuitry that is present on each channel to acquire the inputs from the strain gauges makes it pointless to measure analog voltages.
You can take a look at the
manual to see information on the circuitry for each channel.
I recommend that you use an
analog input module to perform your voltage measurements.
Take care!
Kameralina
