If you install the FieldPoint software (3.0.2 version for LabVIEW 6.1 user and 4.0.1 version for LabVIEW 7 user) you will also install example programs in LabVIEW.
Then if you open the example programs in LabVIEW, there will be a folder with example programs for analog input that you can use with the FP-TC-120 and FP-AI-100.
You can donwload the appropriated version of FieldPoint software from the following location:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C0E2D?opendocument&node=132070_US
I hope it helps
Best Regards
Andre Oliveira
