FieldPoint Family
bind channel diadem not SQL
I'm using DIAdem + Labview connectivity VI's to produce reports. The data is stored on a MySQL DB. No problems here.
I use the "Run automation command.vi" with the following command SQL_BindChannel("CHANNEL_X" , "Value" , "n") to pass the data stored in field "Value" to channel CHANNEL_X. So far so good.
Then DIAdem generates the graphic report nicely.
Now i would like to add some some data to the graphic report, think of it as Upper and Lower limits. how can I do it? I want to pass a constant value
Kind of:
BindChannel("upperlimit", "5.5","n")... My problem is that I don't know the syntax to do it.
Thanks in advance, Alex
(5,749 Views)
You need to post this to the Diadem board.  I don't think you'll get much help in the Fieldpoint board.
(5,741 Views)
