Are you talking about the update rates of the modules or the time to read a channel from your program?
Think of the update rate as how fast the A/D converter updates the channel information that is available to be read by a program. Most cFP modules have update rates that are significantly slower than the PXI and DAQs. I'm guessing that this is because NI decided that most users wanted the industrial hardening of the hardware and not necessarily the high speed. The filter options you choose when you configure your modules in MAX can further slow them down. If you look at the documentation for each module it specifies the speed penalties for different filter settings.
If the problem is how fast your program can read cFP channels, you need make sure that something in your program isn't slowing you down.
