Latley Labview has been running extremely slowly. Running an old VI with no delay between data samples use to output too quickly to see. Now, with no delay, there is a 1.3-1.5 second delay and other timing is erroneous even though debugging shows the VI is running as expected.
To me it seems there is a problem with the Compact Fieldpoint. Browsing MAX didn't lead to any great insight into the problem either. Attached are some VIs we run.
The computer's CPU load is not even 25% and the network usage is below 1% when a VI is active.
cFP-2120
cFP-PWM-520
cFP-AI-100
cFP-TC-120
