FieldPoint Family
Why do I get Error 32812?
I wrote a VI, which worked perfectly.
After addressing the cFP from the network instead of from the PC, some Read tags gave Error 32812.
For one of them I deleted them and wrote them again, and the error was recovered. But then it appeared for another module.
From MAX I can perfectly read the channels. I also tried to "find items" again.
What could be the reason and the cure?
thanks
Francesca
(6,134 Views)
Dear Francesca,
quite a few documents exist on your problem.
I'd start checking into them.
You can use the keyword 32812in the "seach"  field in www.ni.com and find
Why Do I Get Error -32812 When I Read or Write to a cFP-180x from a cFP-2xxx?
http://digital.ni.com/public.nsf/allkb/80A4EF3A7A1784D6862573F4000B20C5
Why Do I Get Error 32812 From Some FieldPoint Modules But Not Others?
http://digital.ni.com/public.nsf/allkb/9DB72AFCBC02D7D986256FC10055D65B
Error 32812 From FieldPoint VIs
http://digital.ni.com/public.nsf/allkb/02EB73D02715981A8625682B00774F8F
Best regards
FiloP
It doesn't matter how beautiful your theory is, it doesn't matter how smart you are. If it doesn't agree with experiment, it's wrong.
Richard P. Feynman
(6,122 Views)
