10-01-2007 06:59 AM
10-01-2007 09:47 AM
Hello Steve,
The FieldPoint driver that supports LabVIEW 8.5 does not support LabVIEW 7.0. Therefore, if you would like to use FieldPoint with LabVIEW 7.0, you will need to downgrade you FieldPoint driver to NI-FieldPoint 4.1. To do this, you will need to Remove NI-FieldPoint 6.0 through the Control Panel then install NI-FieldPoint 4.1. When you need to use LabVIEW 8.5, you will need to upgrade NI-FieldPoint again by using the August Device Driver CD. You can upgrade without uninstalling the older version of FieldPoint.
Please let me know if you have any additional questions or concerns.
10-01-2007 11:04 AM
EXCELLENT CHING.... That worked perfectly.
Merci' beaucoup,
Thanks alot.
Steve Hope
